SDR#: Setting "Order" Value ? (& Filter Quest.)
BOBRR
Boston, MA
Hello,
Might anyone using SDR# explain how to set or optimize the "Order" number next to Bandwith in the RADIO Section ?
Can set Bandwidth O.K. usually by just dragging the edge, but what is the function of "Order", and how to optimize the value for I have no idea. How to go about this, please ?
And, what Filter type have you found "best" ? e.g., Hamming, Blackman, or...?
Same answer for AM, NFM, or USB ?
Thanks,
B.
D
DaveNF2G
Guest
"Order" refers to the mathematical properties of a filter. Google might help with the details.
I have found the default filter settings to work fine. The most critical setting for digital decoding is the frequency correction.
Ed_Seedhouse
Victoria B.C. Canada
In general the higher the order of a filter the sharper it's out of band roll off is. The payback is that transient response suffers, but this is not usually a major problem.
A first order filter rolls off at 6 DB per octave. Second order is 12 DB, and so on.
