DSDPlus SDR Setup Help.
gaushouse1
Hi. trying to use Nooelec RTL-SDR v5 SDR with DSD+ 1.101 on windows 11 and trying to setup all up to receive Ohio MARCS-IP and i have setup the local MARCS-IP tower sites with voice/ control frequencies and I have input the correct format that DSDPLUS requires and i have changed computer sound input and output to what is required and still not getting P25 audio voice just P25 digital sound (Not Voice) I have installed virtual audio cable. I have tried putting correct frequencies in many different files like FMP.Scanlist for example. I have create batch files for DSDPLUS. I am using antenna outside on a roof. I have took info from Digital Frequency Search and selected the format of "FMP-DSD+"
Im requesting assistance.
Thank you.
egear
Orange Beach, AL
Make sure that you have the latest drivers for your Nooelec RTL-SDR v5 SDR.
Make sure that you have the latest version of DSD+.
Make sure that you are using the correct frequencies.
Make sure that your antenna is properly connected.
Make sure that your antenna is located in a good location.
Try using a different audio output device.
Try using a different virtual audio cable.
Try using a different batch file.
gaushouse1
Thank you. May You kindly send Me the latest version of DSD+. the only version i have found is DSD+ 1.101
Thank you
Thank you
DSD+FL is a paid download, it is $15 a year or $25 for lifetime. I doubt anyone on here will send you there copy as they are all linked to the subscription email. Not to mention RR Forums does not allowed sending paid software to other members.
gaushouse1
im kindly requesting latest version of free one not paid only if this helps.
Thank you
ki4hyf
Ridin' Dirty
Jackson, TN
I don't think that version of DSD+ will do trunk tracking. I could be wrong.
NEXEDGE, Con+ and TIII (Hytera) trunking are fully supported, Cap+ trunking is less supported (no rest channel following) in the free version.
It does not mention P25 trunking for version 101. And as a correction to an earlier statement, yearly subscription is only $10, not $15, lifetime is $25.
dave3825
Suffolk County NY
For starters, you should be taking the information listed in the database, not Digital Freq search. And DSDPlus 1.101 is quite old
DSDPlus FastLane version does so much more than the free version you have now. And if you become also radio reference subscriber, you can download talk groups and sites info and paste directly into your groups and sites file.
