Sdr sharp
waterrat
coffeyville, ks
I have been running SDR sharp with dsd+ to listen to my local pd that is Nxdn96. Now they are patching in so much other traffic it is impossible to listen. My question is, what program, if any, can listen to certain talkgroups and ignore others.
dave3825
Suffolk County NY
Are you listening to Coffeeville County Public Safety Coffeyville Public Safety Trunking System, , Kansas - Scanner Frequencies
I believe you should be able to use Dsd+ and fmp. Using this set up, you can lock out and prioritize talk groups. One of the systems I listen to has an encrypted tg and I locked it out..
LMAO If you type coffeeville, it indicates a spelling error. If you right click and look for correct spelling, coffeecake is the first choice....
mrlindstrom
Klein, TX
Like Dave said, DSD+ can accommodate this by using the prioritization numbers.
waterrat
coffeyville, ks
Yes it was supposed to be Coffeyville, and I am trying to get dsd set up with fmp. It is proving to be a challenge so far. I have the downloads, but can not get fmp correct. Do I need two dongles? I finally got hooked up to the control and decoding, Can't hear anything though. How do I set voice channels?
