To the vast experience/knoledge base here:
I have been running an SDRTrunk setup for several weeks and inspite of a lot of tuning, setting changes and hours of research and forum reading, I can't seem to get consistantly good complete audio.
My computer has a Core i5-6500 3.2Ghz 4 core processor, 16Gb of RAM and 128Mb SSD. I am using 3- genuine RTL-SDR v3 dongles. I have added the option in the start up command file to allocate additional memory (" -X4ms4g"). The dongles are staying on frequency showing 0.1ppm error or less.
I am monitoring 2 control channels. I am within 1/2 mile of one tower (simulcast system) and probably >20-30 miles from the other in another county . For the simucast system, I am within raange of other towers. I seem to get better audio from the more distant system. I have adjusted the gain in many comninations, but can't seem to get the magic one! Perhaps a good explanation of the master, mixer, lna and vga gain settings will help, although I have tried many combinations trying to max the SNR ratio.
I have tried different versions of SDRTrunk, and am currently running the latest nightly release.
I have attached 2 audio file links and screen shots of the 2 RTL-SDRs that are on control channels. Along with cut-off and garbled audio, I also get a lot of audio that is empty other than low "static".
https://drive.google.com/file/d/1i3HKYSZpdVJylAkIW19YgHpOwrwHnlyp/view?usp=drive_link
drive.google.com
I would appreciate any insight into what I can change or adjust!
Regards,
Bob
20231204_080430.481.mp3
drive.google.com
Regards,
Bob
