SDR# SDR# v1919 And DSDPlus
Benkasey
Upgraded today from v1918 to v1919, which was working perfectly. Using DSD Interface plugin with vcable and DSDPlus Fastlane. I prefer to use this combo because I have all my saved frequencies and can visually hop around before listing to the decoded digital signal. Anway, in v1919 this doesn't work anymore. The signal isn't decoding properly. I just hear garbled bits of audio. Same combo in v1918 works perfectly. One of the v1919 changes must be affecting this. I see no menu options to modify or disable the changed features. Anyone else having this problem?
Change log: https://airspy.com/downloads/changelog.txt
"Added dynamic scaling of NFM signals according to their occupied bandwidth.
Normalized the internal audio and mpx paths for 0 dBFS
New improved smoothing algorithm for the Noise Reduction.
Improved the MPX Fuzzer"
User128
Also the auxFVO pluggin no longer works with 1919
Only option using spyserver ..
1918 works fine on version 1.1 or the newer one on 1.1.2.0.7 from vasili and mod'd by thewraith ..
HAGO
PDXh0b0
Woodland, WA
AuxVfo works, you just can't put the the SDRSharp.AuxVFO.dll in the plugins folder. If it is in the plugin folder it can't read the plugins.xml so you only get one auxvfo.
dave3825
Suffolk County NY
Are those conventional, trunked or both?
User128
Um , dont want to be a pain , but sdrsharp 1919 throws an exception if auxVFO is in the pluggin folder or any where else - yes i tryed .
and before you ask , clean install , just unzip sdrsharp1919 to a folder on the c: drive insert auxvfo select spyserver and run
in sdrsharp 1918 and all versions before that auxVFO in the plugin folder worked flawlessly just put it in
its own folders auxvfo1 and auxvfo2 and away you go , 2 extra vfos
prog has mentioned it is getting to old for the current version ..
but some of us use spyserver (local lan) and you cant slice that .
HAGO
SKA999
Version 1919 where to download the plugin DSD interface?
dave3825
Suffolk County NY
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Is it possible to use dsd fast line with sdrsharp?
Sure if you like to install extra vb cable software and mess with plugins and audio levels and bandwidth and filtering... sure. As the posts before you say though, 1919 doesn't work.
DSD+ is best and easiest using direct automatic connection to the included FMP(x) tuners which also give you a spectrum display albeit not as fancy looking as the SDR# display+waterfall.
MELERIX
the issue is caused by the changes in AGC in 1919, I've reported it here: DSDTCP - SDR# Plugin but seems the guy who was updating/maintaining the plugin will not update the plugin for the new SDR# versions :( anyway there is a small workaround that I've posted there.
