DSDPlus sdrduo two tuner mode?
melkor41
is there a way to use both tuners in a sdrplay sdrduo in dsd+ fastlane for cc/vc mode? if i try to start fmpp-vc it says -i2 is invalid.
dave3825
Suffolk County NY
Is the Duo supported? Nothing pops in the notes.txt.
FMPP 1.0
DSD+ compatible SDR software for SDRPlay RSP2 receivers.
Other SDRPlay receivers are not supported, but some functionality may be possible.
Operation is similar to FMPA; refer to FMP.txt, FMPA.txt and
FMPA feature updates documented in this change log.
Use Notepad to add your SDRPlay serial number(s) to the FMPP.cfg file.
Not sure if it would make a difference or not, but have you added the serial numbers to the FMPP.cfg?
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
My Duo works fine with FMPP although you can only switch antennas/tuners by pressing the 'a' key so no way to seamlessly utilize both at same time as of now...
DaveNF2G
Latham, NY
What I should have said was, Duo's dual receiver mode is not supported in DSDPlus.
