SDRTrunk/Broadcastify randomly going offline
KeStrite
Goshen, IN
I've been having an issue the past few days were at random times, I will have my Broadcastify feed go offline for about 3-5 minutes, sometimes shorter (although Wednesday night it was offline for about four hours), but apparently it's due to a "Mount Point error" found in SDRTrunk. I've read it can be due to something already being streamed to the mount point, but I'm only running one run of SDRTrunk, and no other programs such as ScannerCast. I've looked in Task Manager as well, and I don't see any other programs that would cause an issue.
I don't think it's a Wi-Fi issue since I'm not losing connection; however, I have considered running an ethernet port just in case.
dlnorth
I had the same problem. Reached out to Broadcastify support and was told that I must have two instances of my streaming program running, which was not the case. They told me there was no other reason to get that error message and were unable or unwilling to troubleshoot further, so I just gave up. I'm in a remote area with limited access to broadband, so I'm using an AT&T cellular router. I read in another thread that other feed providers were having issues using that service to stream. I switched to DSL and had the same problem, so I don't think it's an ISP issue.
