Hello,
I have SDRTrunk using two SDR dongles to feed my local 800 MHz system to a BCFY Calls node and it works well. I have SDR# using one SDR dongle to feed audio from a local 2-meter repeater to a traditional BCFY feed. This, too, works well except for one problem:
When I reboot my computer SDR# ends up grabbing one of the dongles that is supposed to be for 800 MHz. This dongle uses a small 800 MHz antenna that works well for that purpose since I'm a mile from the simulcast tower. SDR# is supposed to use the dongle that is connected to an external 2-meter antenna. Not surprisingly, the 2-meter repeater can't be heard with an 800 MHz antenna.
The only way I've found to "fix" this problem is to disconnect the 800 MHz dongles before starting SDR# so that it only has the correct dongle available. Then I can reconnect the other dongles and start SDRTrunk.
Is there a better way to be sure SDR# only uses the correct dongle? If I'm not home when my computer reboots the 2-meter feed will fail to work properly.
Thank you for your time!
