SDRTrunk SDRTrunk
jsimon003
All 3 of my SDR Dongles randomly started producing the error below. They were all working yesterday and then this morning all 3 were displaying the same exact fault. I've tried everything from resetting the computer to unplugging and plugging the SDR and downloading SDRTrunk Alpha 6.
I am using Noolec NESDR Smart on windows on a hp prodesk
2023-06-06 08:41:54.778 INFO i.g.d.s.t.m.TunerManager - Discovering tuners ... [14MB/56MB 26%]
2023-06-06 08:41:54.880 INFO i.g.d.s.t.m.TunerManager - LibUsb API Version: 1.0.262 [16MB/56MB 28%]
2023-06-06 08:41:54.881 INFO i.g.d.s.t.m.TunerManager - LibUsb Version: 1.0.22.11312 [16MB/56MB 28%]
2023-06-06 08:41:54.900 INFO i.g.d.s.t.m.TunerManager - LibUsb - discovered [7] potential usb devices [16MB/56MB 28%]
2023-06-06 08:41:54.909 INFO i.g.d.s.t.m.TunerManager - Discovered tuner at USB Bus [4] Port [4] Tuner Class [RTL-2832] [16MB/56MB 29%]
2023-06-06 08:41:54.911 INFO i.g.d.s.t.m.TunerManager - Discovered tuner at USB Bus [3] Port [1] Tuner Class [RTL-2832] [16MB/56MB 29%]
2023-06-06 08:41:54.913 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:4 Port:4 - Added / Starting ... [16MB/56MB 29%]
2023-06-06 08:41:54.959 ERROR i.g.d.s.t.u.USBTunerController - Can't open USB tuner - check driver or Linux udev rules [19MB/56MB 34%]
2023-06-06 08:41:54.959 INFO i.g.d.s.t.m.DiscoveredTuner - Tuner Error - Stopping - RTL-2832 USB Bus:4 Port:4 Error: Can't open USB tuner - reinstall driver? - LIBUSB_ERROR_NOT_SUPPORTED [19MB/56MB 34%]
2023-06-06 08:41:54.961 INFO i.g.d.s.t.m.DiscoveredTuner - Stopping Tuner: RTL-2832 USB Bus:4 Port:4 [19MB/56MB 34%]
2023-06-06 08:41:54.961 ERROR i.g.d.s.t.m.DiscoveredUSBTuner - Unable to start tuner [RTL-2832] - error: Can't open USB tuner - reinstall driver? - LIBUSB_ERROR_NOT_SUPPORTED [19MB/56MB 34%]
2023-06-06 08:41:54.965 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:3 Port:1 - Added / Starting ... [19MB/56MB 35%]
2023-06-06 08:41:54.977 ERROR i.g.d.s.t.u.USBTunerController - Can't open USB tuner - check driver or Linux udev rules [19MB/56MB 35%]
2023-06-06 08:41:54.977 INFO i.g.d.s.t.m.DiscoveredTuner - Tuner Error - Stopping - RTL-2832 USB Bus:3 Port:1 Error: Can't open USB tuner - reinstall driver? - LIBUSB_ERROR_NOT_SUPPORTED [19MB/56MB 35%]
2023-06-06 08:41:54.978 INFO i.g.d.s.t.m.DiscoveredTuner - Stopping Tuner: RTL-2832 USB Bus:3 Port:1 [19MB/56MB 35%]
2023-06-06 08:41:54.980 ERROR i.g.d.s.t.m.DiscoveredUSBTuner - Unable to start tuner [RTL-2832] - error: Can't open USB tuner - reinstall driver? - LIBUSB_ERROR_NOT_SUPPORTED [19MB/56MB 35%]
2023-06-06 08:41:54.981 INFO i.g.d.s.t.m.TunerManager - LibUsb Hotplug event notification Is Not Supported on this platform. [19MB/56MB 35%]
dave3825
Suffolk County NY
Did you run Zadig on the dongles? Do the dongles work in any other sdr software? Possible your pc did an update.
maus92
Eastern Shore
Does Device Manager see the SDRs when plugged in? If so, what section of Device Manager are they listed in?
