SDS100/SDS200: SDS 100 changes settings on its own?
ngel
SW Pasco County
Charged my SDS 100 last night. Started it up today and to my amazement it changed some settings on its own. For one the key beep turned its self back on and all my customized colors changed too.
I got it all back after writing my saved profile to scanner again. Very odd behavior.
Anyone else have this happen?
jtwalker
Gettysburg, PA & Fenwick Island, DE
No never.
Did you power it off gracefully, allowing it to save setting to SD card?
Did you make changes on scanner and then write to it from Sentinel without reading the changes in to Sentinel prior?
ngel
SW Pasco County
No never.
Powered it off normally. Did make changes in sentinal recently but read scanner first and then wrote to scanner. But I had used my scanner several times after with no problems and no further updates to scanner itself.
ngel
SW Pasco County
Only thing I could guess other than what I said above is SD card is locked for writes or going h
Not locked, I have never even taken the card out of the scanner. Maybe the card going bad ill have to keep an eye out. I always dismount too prior to unplugging it
