SDS100/SDS200: SDS 100 Virtual Control
sgtmatt
New Glarus Wi
I'm having issues getting both the Butel virtual control to work and Pro Scan, would honestly wrather use Pro Scan. I used to be able to run it but it's been so long that I can't remember how to set things up. Thanks guys. Fell free to move this if I'm in the wrong thread.
RMason
Colorado / Mississippi
Does your scanner show up in Windows Device manager while in serial mode?
Adding to what @dave3825 asked:
Which port are you connecting to on the sds100? Are you using a mini USB cable connected to the "charge" port?
From: Easier to Read SDS100/200 Digital Scanner Manual
Turn on the scanner. When you connect the mini USB cable to the scanner ("Charge" port) and then to a USB port on your computer you will see "USB Cable Detected Select USB Mode" - "Mass Storage = "E" or Serial Port = ".".
Press .no when serial mode will be used for audio streaming, raw data output, and serial control modes in future software from 3rd party developers.
