So I started to have more of a HUM noise again after I installed more Tin Foil. So I took the outside black sleeve off of the radio and still noticed the HUM noise.
So I started to press more pressure on the inner top sleeve that you can take the top off and the HUM noise really sub-sided. Right in the front where the inner metal sleeve is and the black front housing where the LCD display is in the middle of the screen and putting more pressure causing the HUM to actually almost go away. Seems like there is some play or cushion area in between the top metal inner sleeve and where the Uniden mitigation part goes.
So all I did is take the tinfoil and kept folding it in halves and more halves to make sure there is no more cushion in between the part and the outer metal sleeve and put the tinfoil right on-top of the mitigation part and tighten everything down and the noise is almost about gone.
I thought I would start this new thread for serious people that are still having this trouble. NO BS from other people trolling and putting in THEIR TWO CENTS. Just serious people with the SDS-200 radios with the HUM noise.
To the moderator please slap any other people that chime in with no good tech support and give them warnings and delete their post PLEASE> Thank You
