Thank you for chiming in. Might I recomend your engineering team do a simple test to confirm the "improved mitigation" effect of slightly bending the mitigation plate. Simply take any new SDS200, turn it on, and squeeze it by the top and bottom front portion of the outer case over the repair part. The hum/buzz will lessen as pressure is applied. Now slightly bend the mitigation plate up in the middle, reinstall, and repeat the test. The hum/buzz should now be mitigated to the maximum possible amount, and should not increase or decrease in amount when pressing on the case. A modification (convex) of the copper sticker applied to the plate, allowing for more surface contact in the area being lifted towards the center, may also provide a more long lasting improved grounding condition.
Paul
Paul
I would like to apologize about all the troubles that you guys are having with the fix for the SDS200 Hum. I can assure you that I have sent this over to my corporate team where the Factory and Engineering team will be receiving and reviewing.
