I have both a SDS 200 and a BCD996P2 sitting side by side with the same antennas. Both programmed using RR. I live in SW Michigan in a county that uses simulcast, the "Berrien County Simulcast" to be exact. I upgraded to the SDS for simulcast scanning (knowing it was better for this) in another county originally and it works fine. Why does the BCD996P2 only get 5% of the reception that the SDS gets? It should be better than that - it used to be when compared to the SDS for the other county simulcast. What I have noticed it that when I manually hold on a channel it shows "finding ctrl chan". It has the same control channels as the SDS programmed. Is there a setting that I am missing? I have tried to adjust the P25 Threshhold but noticed no differences. Any thoughts as I know these scanners were much more similar side by side when scanning St Joe County Ind simulcast... ???
