SDS100 antenna
Don57
Lindenhurst , NY
I’ve had the SDS100 for about 8 months now and I’ve tried all my antennas including the RH77CA , a telescoping , and a couple of others to try to improve reception for 151-158 mhz. I purchased a W100RX but returned it because I didn’t see any improvement. Does anyone know what would be a better choice. I live in a first floor apartment of a 2 story house so I cannot mount anything outside anywhere. Thanks in advance for the assistance.
Whiskey3JMC
Don't spoonfeed the OP
Simulcastylvania, TE
Don't own one but this antenna optimized for 150-162MHz has positive reviews. You should have seen noticeable improvement with the W100RX over stock antenna but then again I have no idea what your RF environment looks like nor how far the target station(s) is (are) you're trying to pick up. Moving outdoors from your first floor apartment yielded no improvement with the antennas you tested?
Don57
Lindenhurst , NY
I will look into it thanks. I didn’t try outdoors since 95% of my listening is indoors. I’m on Long Island so it’s a very congested area of 2 story houses. The things I’m monitoring are within a 10-15 mile max radius.
EAFrizzle
Bond. Ward Bond
SE de DFW
If you get better reception outdoors with any of your antennas, you might consider a portable-type setup that you can put out for a night of scanning, then take down when done.
Don57
Lindenhurst , NY
I would love to put something outside but the landlord who also lives on the property will not allow it.
EAFrizzle
Bond. Ward Bond
SE de DFW
That's why I suggested something completely temporary and easily removable. Something like a camera tripod sitting outside a window, or some sort of clamp to go on an awning or branch. I get them not wanting anything attached permanent/semi-permanently, this is just something quick to setup and remove with no drilling, nailing, etc. If your landlord has some sort of problem with that, he's being a bit unreasonable.
G7RUX
A full-wavelength loop arranged as a square and attached to a window with rubber suckers works very well in this situation.
Or you could use copper tape or screening mesh strips to do the same.
EAFrizzle
Bond. Ward Bond
SE de DFW
At the very least you could get a good mobile antenna and a mag-mount, and set it on a steel pizza pan near a window.
Don57
Lindenhurst , NY
Even temporary is not allowed. She is very unreasonable but it is her property so I can’t do much about it. I think i have an old mag mount car antenna in storage. I’ll go dig it out and try that on the inside of the window.
EAFrizzle
Bond. Ward Bond
SE de DFW
Yeah, if she won't even let you do that, something in the windowsill is all you can do.
Don57
Lindenhurst , NY
Surprising update on my SDS100 antenna woes. To improve the reception I have tried many antennas including some older Uniden and Radio Shack antenna I had laying around , I’ve tried my RH77A , a Comet W100RX and W100RX2 both of which I returned to Amazon. Then I tried a mag mount antenna that I had laying around and put it on my window sill. None of them improved my reception. About a month or so ago I purchased a Bingfu 20-1300 MHz telescoping antenna off Amazon for $10. I wasn’t expecting much but I figured for 10 bucks wtf. I must say out of all the antennas I have tried this is by far the best. The reception has improved a lot and I’m getting a ton of close call hits that I never got with any other antenna. I was so impressed with it that I bought another one for my HP1. It might not be made of top quality material and the reviews are mostly middle of the road but I have to say my experience so far is 5 star.
rgchristy
Delco, PA
Is this the antenna(s) that you bought:
Ubbe
Stockholm, Sweden
Those other antennas are multiband antennas, design to receive well at several frequency bands. The telescope only receive one frequency band, what its length are set to. It indicates that your SDS100 gets too much signal and overloads using a "normal" antenna. In your case you get better reception the lower the antenna signal are, using a less efficient antenna. The CloseCall function doesn't solely work on signal strength, it has to see a single signal where other frequencies are below its trigger level. Having a too good antenna will have too many signals going above the trigger level and CloseCall stops working, as well as normal scanning reception could be compromised from overload.
/Ubbe
