My SDS100 was programmed from Sentinel and has the following bandplans:
851.00625MHz / 6.25KHz
762.00625MHz / 6.25KHz
SDRTrunk reports the following band plans for the same site, shown in the image.
here's the technical question... Should I add the 12.5KHz FDMA bandplan in addition to the 6.25KHz TDMA one? Its strange because my county doesnt even use P25 Phase 2 yet, only phase 1. The control channel started broadcasting the TDMA bandplan about a year ago. But since the 12.5 is 2x 6.25, shouldn't it not matter becuase the 6.25KHz Channels will overlap the 12.5KHz channels? And with that all said, how does the SDS100 even utilize the bandplan? It knows the CC and Trunked frequencies, so whats the use for bandplan? (This is P25 Specific)
Edit: Now that I look closer at the SDRTrunk image, im kinda confused myself on why band 2 and 3 anre TDMA when the bandwidth is 12.5KHz and so is the spacing.....
