afdscan
SDS100 Battery compartment latch broke today. Has anyone else had this problem?
I've had the SDS100 since 2018 and this is the first issue I've had. I'll check out eBay. Thank you.Very common. There are improved ones for sale on Ebay.
The latches should be the same between the old slim battery cover and the new fat battery cover.The latch broke on my SDS 100 over the weekend. I never upgraded to the larger battery. Are the battery latches the same size for both them smaller and larger battery compartments? Will these fit the smaller battery compartment?
ebay Bart's Scanner Parts
Thanks! Is it still the case that people can't order the part directly from Uniden-- we have to send it in for repair?They are. Also the latches were improved a few years ago.
There’s also a way to adapt a paper binder clip to work… just need the right size. I believe you may find something on it if you do a search on Google because I saw it somewhere on the internet but don’t remember where. I ordered up a stronger 3D printed one when the guy who was doing the GPS installs on SDS100’s was still around. I didn’t wait for the original clip to break-just swapped it out with the new one and tossed the old one. (I wasn't about to carry around elastic bands or tape with me while I waited for the thing to crap out!)
