SDS100 First impressions!
jonwienke
More Info Coming Soon!
VA
Is the security screw and hole below the belt clip stud present only in the beta units, or is it also in the production units?
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
Looks great!!! Care to share your setups for the detailed conventional and detailed trunk in the display customizer in Sentinel?
I know it's a YMMV thing based on what you want/need to see. But I just downloaded the sentinel update and like your setup there. It'd be a nice base to start from and tweak from there..... Hey, if I have to wait to get mine I need SOMETHING to keep me busy while I wait!! ;)
Sure will, just be advised it's still a work in progress.
Houk
  • profile.zip
One13Truck
My home 20 eating pizza.
Houk
Thanks!!! Keep us posted on what you finally settle on. I pulled the info that's displayed in the picture and worked backwards from that but was also curious to see what is in the hidden fields (I was assuming some are assigned but don't show up unless they're active while others are blank).
I figure since you've been able to test for a while you have a head start on all of us on what is and isn't helpful to have in the lists.
trido
Retired 32 years scanner sales
Southern In
P-25 decode settings
Jason,Marshall are there P-25 decode settings to adjust like with 436/536?
thanks
trido
Southern In
yes waiting is hard.
I look forward to NOON monday i take my mind off sds100 for 2 hours while watching the APPLE event.
check your email
Morning Jeff worse than waiting for Christmas
jasonhouk
Uniden AlphaMan
Marion, Ohio
I'm not understanding "hidden/blank"
I use NotePad++ to view so if we're on the same page is helpful to me at least:
https://notepad-plus-plus.org/
download and open with that.
Line 106 starts the screen customization and ends at line 176. Everything else in that profile file is pretty self explanatory like the X436 models.
Houk
CQ
Exosphere
I know we’re all kidding but I m curious of the reason for it and why the beta units had screws and the production units don’t.
Monday morning units? Bob had a rough weekend and forgot?
jasonhouk
Uniden AlphaMan
Marion, Ohio
Totally Agree. I’ve been spending the time working on my database. I needed a good reason to update it.
I only update my FL systems if I noticed a change on my main RR page. With our Statewide MARCS that's weekly.
I've also verified ProScan import/writing FL/Systems is working. The only issue is the display for the 436 will need tweaking.
Houk
Sent from my Moto G (4) using Tapatalk
ProScan
Software Provider
Ontario, Calif.
Houk
Jason,
I been working on the display. One thing I found is the small lines are 36 characters in length and the large lines are 24 chars. length.
Can you do me a favor. Send me a sample of the data received from the scanner. To do that, go into the Options -> General menu and check the option "Scanner Data To Scanner Data.txt File". I just need about 20 seconds of it with radio traffic. Email me the Scanner Data.txt file located in the ProScan folder.
jasonhouk
Uniden AlphaMan
Marion, Ohio
Jason,
PM, me and I'll let you connect to get what you need.
Houk
jonwienke
VA
Can someone please post a screenshot of the SDS-100 receiving a Close Call hit? I'm working on a custom display config that color-codes different types of information (e.g. system info is one color, signal info is another color, channel info is its own color, etc.).
Primary Area 1/2/3 and Sub Info don't offer a clear indication of what lives there. The same is true on the WX and Tone Out screens.
jasonhouk
Uniden AlphaMan
Marion, Ohio
Close Call, I keyed up my Motorola RDU4160d.
Houk
