SDS100-Heads Up
Canyondan
I was curious as to if the SDS100 has a data output that would allow a heads up display while using in a mobile environment.
Thanks for any input.
Hit_Factor
Saint Joseph, MI
There is data on the micro USB port. I think you will have to sleuth the code yourself to program the display.
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
I am sure you could run ProScan on a windows tablet that is translucent/transparent, if there is such a tablet. Tony Stark (Iron Man) always has something like this in his hand, so ask him.
jonwienke
More Info Coming Soon!
VA
A laptop running ProScan and a small projector might work.
sfb88
Baltimore, MD
If you have an heads-up display that you can program, you may want to check out the Remote display thread in the Tavern. here The people working on programming the displays may be able to help you with programming the heads-up display.
