- Joined
- Feb 26, 2014
- Messages
- 43
- Reaction score
- 12
Is anyone having trouble using ARC536 with the SDS150? Software says latest version, but scanner isn't recognized by the software.
You need to verify this via the website and in the app by choosing Help > About. Current version as of this posting is 2.8 Build 2. I don't run the app normally but I previously had been running 2.2 and "Help > Check or Updates" had told me I was running the latest version, which I know for a fact wasn't true. I ended up having to visit the website download the latest versionSoftware says latest version
And you've selected Mass Storage mode?Yes. Mass storage E etc.
Check this post out.Thanks, guys. Using sd card reader with laptop works. Cables still don't
but it's good to have SOME way to update. Really appreciate the thought you put into this.
Some people have experienced issues connecting the SDS150 to computers which have been used previously with SDS100 and SDS200 scanners. Apparently this is caused by a conflict with the older driver. The solution is to uninstall the old drivers, at which the new drivers will automatically install.
Posted in the forum by a user:
- 1. In Windows, with the scanner not connected, right click on the start icon and select "device manager"
- 2. Under the "view" dropdown menu, select "show hidden devices"
- 3. Right click and delete all Uniden serial ports under "Ports (Com & LPT)" in the device tree. I my case, I had 3 Com ports listed.
- 4. Power on the scanner and connect it.
- 5. Set the scanner to Mass Storage mode when prompted on the screen. The Sentinel software will now install updated USB drivers
- 6. You should now see a new drive letter for the scanner in the File Explorer, and Sentinel will now be able to read & write to the scanner
