SDS100/SDS200: SDS200 and GPS
arlo
Can I use my 536HP GPS on my SDS200? If so, which port and what kind of adaptor?
jtwalker
BEE00.1E8
Probably. I’d say it depends on which gps puck you have.
The SDS200 uses an RJ-11 (I think, either way it’s a landline phone plug) to connect to gps. Jack is on back of 200.
arlo
This GPS is Uniden and came with a BCD536HP. It has a large USB connector.
jtwalker
BEE00.1E8
Uniden has at least two different models. As part of the cabling do you have a phone plug connector?
arlo
No, I do not have a phone type connector-adaptor.
jtwalker
BEE00.1E8
I had the round puck from Uniden for my SDS100. When I bought an SDS200, I found myself in same situation as you. There may be a cable adapter that you can buy or make, but I just bought the newer rectangular puck from Uniden that had proper cable.
Others might have better (more economical) suggestions for you.
dave3825
Suffolk County NY
If you bought the Uniden kit, with all shown here, then you should be able to.
If you just bought gps for the 536, then you need to get something to end up with a rj 11.
arlo
The GPS that I have came with the 536. I do not have that nice kit.
What is the advantage to using GPS with a Uniden scanner?
dave3825
Suffolk County NY
Only advantage is if you travel with the scanner, and use gps, it can load stuff to listen to based on what service types you select. Works with full database and favorites lists.
arlo
Thanks to all. I learned a lot. Will not try to use GPS.
dave3825
Suffolk County NY
If your only using it at home, all gps is going to do pretty much the same as entering in your zip code.
Markscan
New Jersey
The 536 did not include GPS, but it did come with a WiFi dongle. Is that what you were referring to?
arlo
It is a BC-WF1. Very dim engraving on back. Thanks for helping.
