SDS200 GPS PUCK
hiegtx
Dallas, TX
I'm not so sure of that. The SDS200 uses a totally different type cable than any of the GPS capable Uniden scanners. It's a "one piece" accessory that plugs into an RJ-45 port on the back side. Unlike the GPS used for the SDS100, the x36HP series, and the other`scanners that can be attached to a GPS, there is no separate power cable for the puck. I have not seen a cable that would convert the GPS module used for the 536HP to match the SDS200. I suppose if you knew the correct pin outd for the SDS200, you could fabricate something to work, but nothing that is currently available pre-made.
  • Like
Reactions: RRR
hiegtx
Dallas, TX
ABSOLUTELY NOT. The cabling is different, and the SDS200 uses 3V TTL signaling, while the 536 uses +- 6V RS232 signalling.
Thanks John
Since it's a totally different output & voltage, you can't put enough lipstick on a 536HP puck to use it on the SDS200.
KAZ7ED
What baud rate setting should be used on the SDS200 - CB-GPSK?
N9WI
I use 9600. In Sentinel, go to Profile, Location Settings, GPS Options.
jonwienke
More Info Coming Soon!
VA
If that doesn't give you the GPS indication, use 4800. All of the other Uniden pucks use 4800.
N9JIG
Sheriff
Moderator
Far NW Valley
Check this guide to the Universal GPS Kit, it will help explain how it works with various scanners. The matchbook style GPS uses 9600 baud.
