Seems like another rush to production...
But at least they issue recalls or TSBs ...Same thing goes on in the auto industry year after year.
This is very true. That is why I don't understand Uniden's apathy regarding the problems with the SDS200. They may have a monopoly in the market but it can still hurt them badly.
Sorry but my edit time ran out.. Here is the full version of the above post:
Here are my 2 cents on this hum issue..
In the beginning I reported that I could not hear the hum. Well if I have the audio time off setting to infinite and have ear plugs in I can tell it is there but not terrible. Very, very low with internal speaker and could not hear it with an external speaker unless it (like the ear plugs) is up against my ear. So NO, as far as I am concerned there isn't any hum from my radio.
Regardless...
I took the cover off and I do have a factory installed NMP200 so I removed it.. The hum did get much more noticeable!
So I took it all apart to see what, if anything could be done and here are my findings at this time:..
The NMP200 simply connects the "screen ground" of the display to the chassis.. That is it!! (which explains why, over time, people start hearing the hum return - loose fitting part and oxidation.)
So on further inspection I see that the "screen ground" is in fact soldered to the front board's ground plane pretty well. I also saw (the main issue I am about to explain a fix to) is the four mounting screws that hold the front board to the chassis ARE NOT CONNECTING the front boards ground plane to the chassis! Which in fact is EXACTLY WHAT THE NMP200 DOES. Simple fix really... without soldering! (or voiding your warranty ~ just a disclaimer for the warranty police on the forum so they will finally STFU already!)
The tools I used:
No. 1 & No. 2 Phillips screwdriver
Small flat jewelers screwdriver
X-Key tool
Credit card (or similar to not mar the faceplate or knobs upon removal)
X-acto or utility blade
To help removal of the wire plugs that connect the front to the main boards I used curved hemostats
If your eyes are going (like mine are) some type of magnification
Once you have the radio taken apart (explained elsewhere on the forum) and have the front panel in your hand, display towards you, you will see four (No. 1) screws towards the corners of the front board (notice the green lacquer all over and under the screw heads?). One at a time remove the screws and CAREFULLY scrape the lacquer from under the screw heads but DO NOT SCRAPE AS HARD THAT YOU REMOVE THE COPPER FROM UNDER THE LACQUER!! and replace the screw. Now to make sure you have good contact, tighten, loosen, tighten, loosen and tighten the screw a few times.
Now carefully put the scanner together without the NMP200 and test..
I hope your results are as satisfying as mine..
If you do anything I have explained here, you will not hold me responsible for anything that may happen, what-so-ever. You will assume full responsibilities for your own actions (which you should always do... period!). This includes but not limited to the leakage of liquids from your body due to the misuse of sharp objects!
Normal scanning may now resume...
Well I just lost more of my eye sight figuring out this fix. You can't do this fix without an X Key Tool. It was not an easy task getting this fix taken care but it worked like a charm. No mitigation part or no tinfoil now. The HUM IS COMPLETELY GONE FOR GOOD>
My external speaker also does not have absolutely NO HUM Noise now. This is the perm fix.
Also, I do not have the "Set Audio Off time" set to 100ms. I can keep it set to Infinite.
Now I finally have a solid radio now
What tool? Something like this? How does it come into play?
Amazon.com: AOER Silver X-Key Repair Tool Destuffing for Two-Way Radio Walkie Talkie Motorola GP-300 GP-88 GP-328 GP-328plus Puxing PX777(PX-777) PX-777plus PX-328 Baofeng UV-5R WOUXUN HYT TYT PUXING Radio: Home Audio & Theater
Amazon.com: AOER Silver X-Key Repair Tool Destuffing for Two-Way Radio Walkie Talkie Motorola GP-300 GP-88 GP-328 GP-328plus Puxing PX777(PX-777) PX-777plus PX-328 Baofeng UV-5R WOUXUN HYT TYT PUXING Radio: Home Audio & Theaterwww.amazon.com
Perfect, so...something like what I linked? Would that one work?It allows you to take the nuts off of the volume, squelch and function potentiometers to separate the face plate from the front board with ease.
It's like getting the Christmas morning feeling you were hoping for when you first turned it on. Just a little delayed. Lol.Well I just lost more of my eye sight figuring out this fix. You can't do this fix without an X Key Tool. It was not an easy task getting this fix taken care but it worked like a charm. No mitigation part or no tinfoil now. The HUM IS COMPLETELY GONE FOR GOOD>
Yes that's itPerfect, so...something like what I linked? Would that one work?
Well done. Any pics will further help and encourage those that may be hesitant to do it. It's not difficult it just takes a steady hand and patience to not hurry.Here are some pictures of how its done. I used just a straight edge razor blade and took my time. Time is key. Do not hurry this process. Scrap a little at a time until the copper shows for all 4 screws. Once I was done and before putting the face plate back together I took a micro fiber cloth and cleaned the LCD since you get small lint particles all over the screen and the protective face plate screen cover.
Your right, it is. But to verify no one is having anyone do anything. All voluntary.This is something Uniden should be doing. I think it's unreasonable to have owners disassemble the radio like this.
Exactly why they have apathy and berate people that raise issues and concerns like many do here. Never taking any responsibility. Really unprofessional and immature.This is very true. That is why I don't understand Uniden's apathy regarding the problems with the SDS200. They may have a monopoly in the market but it can still hurt them badly.
