My goal was to be able to remotely access using ProScan via my cell phone to lock onto one department in particular if something interesting is happening with that particular one department (channel). I wanted to lock onto that one particular department (channel) so that there would not be any interruptions from other traffic that would be occurring within the Favorites List of departments at the same time the interesting traffic was occurring from the one particular department (channel).
Utilizing "NUMBERS" seems like one way to accomplish selecting one channel out of many within the Favorites List, but I am so confused by how to set NUMBERS up, and even after experimenting with programming to accomplish this, I just could never get them to work.
The PRIORITY feature doesn't seem to be an option with respect to setting up a priority channel, if that channel is trunked P25. So, the PRIORITY feature seems kind of useless for accomplishing what I want to accomplish. In addition, as was mentioned, the interruption when the scanner switches to PRIORITY is an annoying interruption to other traffic within the Favorites List.
So, for now, until I can learn how to setup NUMBERS within the Favorites List, and learn how to lock onto one particular NUMBER within the favorites list, I've had to come up with a work around.
I set up a separate favorites list with the one particular department in it. When I want to monitor only that one department (channel), I turn off the favorites list containing all the departments in that County, where the one department is also programmed, and turn on the favorites list that contains only that one department (channel).
It works fine accessing a separate favorites list to lock onto the one particular department (channel), but I can't help but think the NUMBERS method might be the more correct method of locking onto the one particular department (channel) that's programmed in the original County Wide Favorites List. But, when experimenting with programming and accessing NUMBERS, I must be doing something wrong when trying to access NUMBERS programmed into the County Wide Favorites List because it rejects my entries when I attempt to do so.
