SDS100/SDS200: Sentinal Software (USB Drive ??)
Saint
Fort Erie Ontario Canada
SDS100 Radio
Sentinal Software
Every time I Try and Update Software or Write to the scanner the software keeps poping up my : F drive were the BCDX36HP Directory is. I have to close the window to do anything else. I this common or is there a problem with the software. Should I re-download the Sentinal software and re-install it ??
Steve
RandyKuff
Lorain, Ohio
Just out of curiosity... With sentinal open... What is it showing when you click on "Tools" and "Options".
Sentinal usually puts it's default folder (Uniden) in your Documents folder.
RandyKuff
Lorain, Ohio
It looks like your writing all your stuff to "One Drive".
Look for "Uniden" folder in your "Documents" folder on your computer. Thats where it should be pointing to.
Saint
Yea I found the Uniden folder but I can not change the path to it in Sentinal software it wont let me ??
Steve
RandyKuff
Lorain, Ohio
If you need to pull the audio files you recorded from the scanner... Pull it from the audio file folder on the scanner itself in USB mass storage mode thru file explorer.
RandyKuff
Lorain, Ohio
Steve
Did you click the Three dot's next to the path? So you can navigate to it
hiegtx
Dallas, TX
Steve
You can change it in Sentinel.
Click on the Tools drop-down menu.
On that menu, choose Options
75879
Saint
Yes when I click on the three dots Apop up box comes up and it says browse for folder. down at the bottom of the box it says make new folder. I click on the uniden directory and it does not change in Sentinal software to the directory
Steve
RandyKuff
Lorain, Ohio
Well... The only other sugestion I have is... Uninstall it...
Then reinstall it... But right click on the setup.exe file and "Run as Administrator"
Saint
Ok I had to go to another part of my harddrive to make the changes it seems to be working, thanks for all your help I would not of figured it out as fast without your help.(y)
jonwienke
More Info Coming Soon!
VA
Permissions on the default folder are messed up somehow. Fix the permissions and you don't have to make a new folder.
RandyKuff
Lorain, Ohio
I see he shows an F: drive in his first post. If he moved his libraries from his C: drive and didn't do it properly that can cause problems too.
Ubbe
Stockholm, Sweden
It's a drive on the cloud, so could be all sorts of security problems that Sentinel are not designed to handle.
/Ubbe
jonwienke
VA
Good point. Sentinel data should be on a local drive.
Saint
Thanks for the help everyone, as soon as I changed the Sentinel Icon and changed it to Run as Administrator I was able to change to the Uniden Directory everything is ok now. Thanks for Your help.
Steve
