BCD436HP/BCD536HP: Sentinel problem
TGP
Metro East, IL. St. Clair County
Not sure what happened.
Updated sentinel to Version 1.03 (revision 01)
And shows no new firmware update (trying for 1.05.01)
Currently the radio has 1.03.00 firmware.
When I connect USB and select mass storage it won't read from the scanner or write to it.
Was thinking a driver problem but the radio will ask to or charge from the pc,
Any Ideas?
Tom
TGP
Thanks I have read all that.
My drivers appear to be recognized by windows and I never had to remove the card before.
But I guess there is a first time for everything.
I will try that and see what happens.
Thanks,
TGP
TGP
Well I removed the sd card and used a reader and it updated fine.
Still don't understand why I had to do that?
Thanks for your help.
Tom
phask
zanesville
99.99% chance it's seing the incorrect driver in device manager. Fact is, none needed , it should see it as a mass storage device.
Connect it,open device driver, find it, delete it.
Tom
TGP
That makes sense.
Is it possible that it's reading the driver for bcd325/996P2 used for freescan?
TGP
Voyager
Unlikely, as one is a mass storage device and the other is a USB-Serial converter.
D
darunimal
Guest
Very likely it miss read drivers. I had to uninstall drivers for BCD325P2 to add the BCD436HP into the system, 2 weeks ago, after that I haven't had any problems. I purchased the BCD536HP first; I can't remember if I had to remove BCD536HP driver to get Windows to recognize the BCD325P2 (second). But I was surprised when the BCD436HP had a problem connecting. I have WINDOW 7 ULTIMATE 64bit and don't have driver problems, usually, because I'm admin all the time, UAC doesn't throw corruptions into things like lower end Window 7 and Vista systems do.
CalmWind
DFW area
I agree about it the USB connection should work without any extra drivers being loaded. I tested on Windows 10 and 8.1 Desktops and the connection was made without problems.
However, I was trying to get it to work on a Dell AIO and the device was not being recognized. Possibly because of how the USB ports are set up, but I gave up on that system, I will probably need to change something in the bios to get it to work.
I should note, this problem system has been rolled back from Windows 10 and may have special problems in some areas.
CalmWind
DFW area
I However, I was trying to get it to work on a Dell AIO and the device was not being recognized. Possibly because of how the USB ports are set up, but I gave up on that system, I will probably need to change something in the bios to get it to work..
I ended up resetting the USB Hubs in Device Manager and the link was recognized and worked normally after that.
I have seen situations with normal card readers which had been removed using the Save Removal, had left the system with an unresolved driver situation and needed to be rest.
