Sentinel will not start under Windows 11
DaveNF2G
Latham, NY
I have attempted to install Uniden Sentinel x36 on my new Windows 11 laptop. The installer runs, but when I try any tactic to start the program (click on desktop link, click in Start Menu, double click in Explorer), nothing happens. No error messages. Sentinel just does not start.
I have verified that I have Execute permissions on all links and on the executable.
fxdscon
¯\_(ツ)_/¯
It's an occasional issue that Sentinel's "user.config" file becomes corrupted and will prevent Sentinel from starting and running after it's installed.
Try this... (If this doesn't fix the issue, it won't cause any harm) :
Before trying to run Sentinel again, go to Windows Explorer and look for this folder on your computer:
C:\Users\[YourUserName]\AppData\Local\Uniden
In that folder, you will see a sub-folder that begins with "BCDx36HP_Sentinel.exe_Url_"
Delete that entire sub-folder (it contains the "user.config" file).... be sure you are deleting just that specific sub folder. That sub folder does not get deleted when you un-install Sentinel, so if the "user.config" file in there is corrupted, it will still be there (and corrupted) when you just try re-installing Sentinel.
Re-start Sentinel... When Sentinel starts, it will re-write a new folder to replace the one that you deleted, and a fresh "user.config" file will be in that folder.
DaveNF2G
Latham, NY
Thanks. I will give that a try when I get home.
DaveNF2G
Latham, NY
I think the installer does not complete on Windows 11. There is no Uniden directory in AppData, nor is there a user.cfg anywhere on the drive.
fxdscon
¯\_(ツ)_/¯
Do you get any error messages that say .NET 2.0 is needed when running the Sentinel installer?
Also, if you searched your drive for "user.cfg", try searching the drive for "user.config"..... that's the file in question.
Are you looking in "C:\Users\[YourUserName]\AppData\Local\Uniden"
DaveNF2G
Latham, NY
I get no error messages during installation or when I attempt to start the program.
I sent a message to Uniden support.
jtwalker
You’ll need to check Windows event logs and find out what is going on. No way Uniden will be able to help you given what you have provided here.
There is an error/exception somewhere to provide a clue as to what is happening.
DaveNF2G
Latham, NY
Per suggestions here and responses from Uniden, I have ensured that .NET is installed and fully enabled, tried various install methods (setup.exe as Administrator and not, and the .msi installer), tried various methods of starting Sentinel (as Admin and not), and still cannot get a response from Sentinel after it is "installed successfully" in Windows 11. I also still have the same missing subdirectories under AppData/Local.
I also tried the Repair option in the .msi installer.
fxdscon
¯\_(ツ)_/¯
There was one instance similar to yours a while back where the .NET 2.0 was installed but had become corrupted causing Sentinel not to run after being installed. The following procedure was successful in getting his Sentinel to run.
To repair Windows .NET framework..... in the Windows search bar, search for "features", and then click on "turn Windows features on or off".
Once that window populates, look at the checkbox next to ".NET Framework 3.5 (Includes .NET 2.0 and 3.0)”.... it's usually the first line in the features window. Un-check that box, click "ok" and reboot the computer.
Now go back to the same area noted above and re-check the box for ".NET Framework 3.5 (Includes .NET 2.0 and 3.0)”. Click ok and reboot the computer again. Now see if Sentinel will run.
If that doesn't help, you'll need to start tracking down other suspects that may be blocking Sentinel such as anti-virus software, firewall settings etc.
G7RUX
Windows 11 has been troublesome when installing and using "untrusted" applications. Two things to look at in Setting are "Smart App Control" and also "Controlled Folder Access" in "Ransomeware Protection."
Other users have reported success with this issue by looking variously to disable these features.
dmchalmers
same issues not impressed with windows 11 issues at all. Aboutready to give up with sentenel an go all sdr. 40 year Uniden fan but not so much anymore.
buddrousa
I am running Sentinel just fine on a Windows 11 PRO 64 bit laptop we know it works. Contrary to everyone's thinking Windows and software is not plug and play you have to have a little IT in you or know someone that does. Also gone in this day and time is the little do it yourself repairs and tune ups for your car.
Ensnared
Waco, Texas
I had difficulty with Sentinel until I got a computer with Windows 11 Pro. The computer tech indicated that Windows 11 problems are widespread. The computer came with Windows 11 Pro, but he still had to reload Windows for some reason.
dave3825
Suffolk County NY
