serial numbers ?
gordwa
crown point in.
Hello...Im fairly new to the SDS 200 and wanted to down load the NXDN software from unidens site. It asked me for my ESN number witch i am taking is the one when i go to my firmware version witch is a 14 number SN but i can only fit 12 numbers on the first line at the down load site. Now the SN on the back of the unit its self is only 12 numbers and 12 will fit .What SN number should i use? The second line below the first is for a checksum number witch i assume is the last 3 digits of the firmware version of the SN...Thanks for any help I hope this is not to confusing .:)
N9JIG
Sheriff
Moderator
Far NW Valley
The serial number needed for REGISTRATION at my.uniden.com is the one printed on the label and starts with "384Z".
Once registered (when you want to purchase an update) use the Electronic Serial Number (ESN) located by pressing Menu>Settings>See Scanner Info>Firmware Version. This will look like "384260...". The SUM Code requested will be the 3 characters after the dash.
Like Tvenger said part of the ESN will be pre-entered as they refer to the radio model which you will already have selected before you can enter the ESN.
gordwa
crown point in.
Hey thanks for your help. I finally got the serial number straightened out and my download so thanks again....
