BCD325P2/BCD996P2: serial port not available
graphics55148
Yay! Problem solved: The software (ARC) was not detecting the correct COM port. Noted a side comment in another thread that Fireboat03 was using ARC w the 996p2 w/ WIN7 and not having problems so I asked a follow up in that thread.
To summarize - for "serial port not available"
Downloaded the driver (Uniden from the 996p2 WIKI); unzipped; installed
In Device Mgr: R clicked >>ports and matched the baud rate, confirmed the COM in the advanced area
In SW (ARC): went to the scanner tab along the top, opened communication set up and matched the COM/selected autos elect scanner.
Uploaded my frequencies and am in business. Cannot wait to take it to my Dad tomorrow- it's going to absolutely make his day.
Thank you again for talking me through this-- I was getting so frustrated.
Voyager
The fact that the FreeScan test worked indicated that there was no driver issue, and that the issue was in the software since that's the only thing that was different.
storminc
Have similar issues with 536 and Arc Butel Sotftware. It will upload download Frequencies but will not go into Virtual Control....says to install Driver. Butel no help says it is a driver or cable issue. I do not recommend their software they have worthless support. Using Proscan. This program works perfectly so I know it is not a driver or cable problem. Any suggestions on Butel program as I have already paid for it. Thanks
Sent from my SM-G920V using Tapatalk
storminc
Have downloaded a newer version of Butel Software for 536. Now everything works fine. It was obviously a software problem. Butel should inform their Techsupport so they will not blame a problem on Uniden
