Setting Up MC1000 Deskset Remotes
SypherAK
Soldotna, Alaska
So, recently the wiring for our station's MC1000's was botched. They now do not transmit. Does anyone have an installation guide or even a basic pinout of the wires for the remotes?
Project25_MASTR
Millennial Graying OBT Guy
Texas
DC or tone remote?
It’s been slightly over a year since he last time I messed with one.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
I am currently working on several of these at a Nuke power plant. Open the cover by removing the 4 Phillips screws holding the top and bottom clam shells. You need to know if you are 2 wire or 4 wire in your system. Set up the 2w/4w jumper, then wire appropriately. So easy a salesman could do it....... TT
SypherAK
Soldotna, Alaska
MC1000 Type
They're 3213 Tone Control Handsets. But, they don't need any control functions. All they need is PTT and audio.
TampaTyron
Phoenix, AZ
None that I am able to share. Let me see if there is anything publicly available. Do you know if you have 4 wire or 2 wire audio? TT
TampaTyron
Phoenix, AZ
I am not able to share due to employers policy of sharing info not that is not widely distributed. It is based on the belief that giving you the info cuts another local dealer out of the loop. Since the six figure job is paying me more than providing free help to the internet, I choose the money. Maybe that makes me a bad person, don't know. TT
TampaTyron
Phoenix, AZ
So, a 2 wire circuit could be landed at 2w- and 2w+ along with 12vdc landed to their terminals.... then it should be up and running if you have the default tone plan and the desksets is configured for defaults. If you have access to MOL, then the manual is there. The programming mode and options are not very intuitive and difficult to describe over the net. TT
rescue161
KE4FHH
Hubert, NC
What radio is attached to the tone remote? Is there a tone remote adapter? Do you have more than one remote? If so, are the other remotes working correctly?
Project25_MASTR
Texas
The only place you'll find the manual currently is either in the box with the unit or on MOL. Hasn't made it into the wild yet.
