Sevier County LTR?
K
Kcomm
Guest
There are many digital technologies in operation today; grouping them all together in a broad "digital" statement isn't very fair, as they're like comparing apples to oranges. Mototrbo is TDMA, 3GPP LTE is OFDMA/FDMA, most cellular is W-CDMA. Not even remotely related outside the fact that they're all broadcast over the air. CDMA, TDMA and FDMA all have their disadvantages, but if one looks at cellular technology, they're effectively abandoning TDMA(and CDMA to a degree) in favor of FDMA.
nauss
It is hard to believe that Sevier County cannot get the money together for a good system. They have the largest revenue in the state behind Shelby and Davidson counties. Maybe Dolly Parton will spring for it if they ask her. HAHA
hcpholder
Sevier County LTR 800?
I see that the Sevier County LTR system is now show 800 freqs instead of the 400's shown a few weeks ago. What's going on? Should I leave the "previous 400 system" and setup a new LTR 800 TSYS in my Pro-106?
icom1020
Is the 800 system a beta to see if it will actually work?
n4yek
Cosby, Tennessee
Just monitor the UHF freqs, you won't miss anything. You can't hear 800 MHz in Gatlinburg except in spotty locations, it is very weak and is just a simulcast of the UHF system.
holeinace
Kokomo, IN
I was in Wears Valley for several days and did not hear anything on the trunked systems. I did not listen full time because I got mad and wanted to hear something. The conventional frequencies would have come in better had I taken the correct antenna.
n4yek
Cosby, Tennessee
Thats odd... the trunk system is very active. Unless you were in the 'Dead Zone', you should have received something. Wears Valley Fire Department uses it so you should have been able to hear it, the UHF system covers that area pretty good.
holeinace
Kokomo, IN
The UHF was great as was the Park. I was in a hurry when I programmed the scanner so I may have done it wrong. I will be returning in August. I will have plenty of time to mess with it then cause it will be too hot to hike
khvfdff
Keystone Heights, FL
Personally, I feel that what is in the database is a little confusing. I was just up to that area about a month ago on vacation. What I think needs to be done with the database is that all the talkgroups need to be listed by what site they are on. All with the accurate control channels and talkgroups.
I do tend to get a little impatient when I am somewhere and I prefer to have my stuff preprogrammed. The whole time that I was in Sevier County all I heard was the Sheriff's office. I never once heard the fire departments except on the appropriate conventional tone paging frequencies. I was kinda disappointed in this.
Yes, I had everything programmed as it said in the database. I was using a BCD396T. Also for the GSMNP, I only heard the analog channels all the digital channels were coming in with what sounded like databurst.
Other than that, throughout the entire state of Tennessee and Georgia all the way up there and on the way back home I was very pleased with the channels and they were all easy to figure out. The UHF Med Channels did catch my attention when a hospital was being called with their own special tones.
gsquared18
Knoxville, TN
Conventional, P25, linked repeater system.
I'm a scanner noob so I don't know what that means but I'm always trying to listen to the park rangers when we go to Cades Cove or stay in our cabin behind Dick Clark Theater but never get anything. I even tried to listen to a ranger directing traffic for a bear alert on the Cades Cove loop with Close Call and got nothing. Do they use a system or convetional freqs?
kel415
Kodak,TN
Park Rangers
I have a pro106 and listen to the park rangers every night, N4yek is right they are on a p25 system on 169.550000. I live in kodak Tn ( north of I-40) and I hear them well and everything else in sevier co. Pigeon Forge FD is digital. I put my scanner on search sometimes and pick up some odds but not really much going on in 700 range only Knoxville was testing about 5 freqs but no traffic on them now. I have pick up a few here this week but still looking at them (700 freq)
gsquared18
Knoxville, TN
Ok so based on that frequency, they're on a digital system and my Uniden 330T can't pick it up.
kel415
Kodak,TN
Yep, like n4yek said many to pick from so instead of putting all of them in there I just put my scanner on search till I got the best signal which is 80% so I just stuck with that one.Just so happens it was in my back door and sounds good. Someone tell me why they say "break" and not say anything for few sec.and then talk again. Sometimes it sounds like their radio fades out just before they do that. Just wondering I'm not new to scanning (pro94,94b) then got this pro106 and I'm really trying hard to catch on to this high tech and I think it may be over my head some.But really found a great deal of info on this site by just reading. Thanks to everyone Ronnie
W4EMS
NoVA
Most of the time "break" is used to break up a long message in case another unit has urgent traffic that cannot wait for the long message to complete. I hear it most often on BOLO's (be on the lookout for). If no one interrupts they continue/complete the message after a brief pause. Good amateur radio operators do the same on nets or busy frequencies.
Doc
gsquared18
Knoxville, TN
So they just use one frequency for their main chatter? Can this be heard on on analog radios or just digital? Kel415 said he hears them on a "p25 system on 169.550000" My BR330T can only do 4 numbers after the decimal so I'm assuming 6 after the decimal means digital. I'm digitally a dummy.
n4yek
Cosby, Tennessee
No, all communications take place on ALL the frequencies at the same time. They are linked together. With the exception of 'Local' which is basically talking to each other in simplex mode. He might hear them best on 169.5500MHz at his location, I don't. My best frequency is 172.500MHz and that is the freq I listen to them. We both hear the exact same thing at the same time from the same person.
You need a radio capable of decoding P25 in order to monitor the communications from the National park. Once in a blue moon you might hear someone transmit in analog.
That is just how he typed it on here, 169.55 is the same as 169.550000. The indicator 'P25' tells you it is digital
