Sevier County Public Service Systems
n4yek
Cosby, Tennessee
Pittman Center Police are being dispatched by the Sheriff and also use talkgroup 1101 along with the Sheriff.
The Sheriff department unit number are in the 100 & 200 range while the Pittman Center Police unit numbers are in the 900 range.
Seymourmtn
Seymour, Tn
Please enlighten me
Got another ID:
1701 Gatlinburg Fire
Heard them dispatched to Cherokee Orchard Rd
Greetings from a newbie!
Pleae enlighten me as to what I need to get my Uniden x36 to receive NXDN.
I have been following this link, live in Sevier county and am confused.
Any help appreciated
Doug
INDY72
Indianapolis, IN
No currently manufactured scanner can decode NXDN, DMR, OpenSKY, ProVoice EDACS.... If you use raw audio from the discriminator tap point to feed into your computer, you can use software such as DSD+, etc to decode the system. As long as there is not encryption being used that is. or you can use an antenna running into the computer and run an SDR program and the aforementioned DSD+ etc...
tennesseefreq
Seymour, TN
License Info
OK it has been born in the DB.. I will get GPS data, FCC data etc fixed as we get it all narrowed down. TY guys for all the great help so far!
FCC Data are the Licenses with the radio service of CP.
License Search Results
Licenses specific to this system
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS337 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS338 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS339 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS340 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS341 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS342 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS343 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS344 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS345 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS346 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS347 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS348 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS349 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS350 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS351 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS352 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS353 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS354 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS355 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS356 - Jenkins, Micheal H
ULS License - Part 22 VHF/UHF Paging (excluding 931MHz) License - WQMS461 - Jenkins, Micheal H This is where the Sevier Co TwoTone Paging frequency is.
Cover Maps sent to FCC
BEA044 - Knoxville, TN
ULS Application - 0005939069 - Jenkins, Micheal H - Administration
INDY72
Indianapolis, IN
This is going to be fun.. Each site's FCC data will be longer than the actual frequency listings LOL!
tennesseefreq
Seymour, TN
Site 4 found
I have located Site 4, it has a RAN of 4.Shows two adjacent sites, Site 1 with control channel #165 and Site 3 with control channel # 167. Have seen talk groups 1101 and 1501 on this site. Appears to be located near the interstate in Kodak, frequencies below.
Ch# 160 454.5875 is control channel
Ch# 112 454.2875
Ch# 128 454.3875
Ch# 144 454.4875
INDY72
Indianapolis, IN
Ch# 112 454.2875
Ch# 128 454.3875
Ch# 144 454.4875
Good catch, will also add it by Tuesday
n4yek
Cosby, Tennessee
Went for a drive and found Site 2
It is on Ski Mtn in Gatlinburg,
35.703413
-83.565751
Was sitting right next to it without and antenna on my radio, sitting on my seat, inside the car and it was full scale.
n4yek
Cosby, Tennessee
https://wireless2.fcc.gov/UlsEntry/...tachmentKey=19279293&attachmentInd=applAttach
I was looking at this map and I can probably say that site 3, which is the strongest site to me here at my house, is located on English Mountain.
I receive it just as good as the Land Air LTR English Mtn site.
Being that Land Air owns the NXDN trunk, I would say NXDN Site 1 would be located on Greentop with the LTR Greentop system as I receive both of these equally well.
tennesseefreq says site 4 is in Kodak somewhere close to the interstate.
With site 2 confirmed on Ski Mtn in Gatlinburg from post #32, looks like we can say we have the locations now.
INDY72
Indianapolis, IN
Awesome. Thanks guy for all the hard work, now I will get things rolling deeper in the db tomorrowish. This will be my first set up of an NXDN TRS, besides just updating the TN DHS D7 upgrades... Which I think are all almost done to convert it. Next I am tackling a couple of DMR ones.. One being an almost statewide in MS, another is an very big one here in TN. (Covers pretty much most of Western TN)
INDY72
Indianapolis, IN
OK.. Nerxt up we get the right GPS for the other 3 sites, and accurate ranges set for them.. And am pondering if the other sites listed on their FCC data is also NXDN TRS? If so, this network extends to the surrounding counties and is most likely for the businesses in the area.... if anyone happens to ride up to Knoxville area, and anyone does a loop around the Sevier County neighbors and can find other sites using these whacky freqs for NXDN TRS.. let us know. Because the FCC mapping shows like 10 sites.
INDY72
Indianapolis, IN
OK, just found out that the newest DSD+ decodes the System ID for NexEDGE TRS's. So if anyone can give it a run and nab the NID for this one, much appreciated!
n4yek
Cosby, Tennessee
Two more id's:
20 is Timber Tops Cabin Rental
22 i believe is Bakers Towing, the SrcAlias is showing Bakers
DsdPlus is a great program
