Here they are (taken from
here):
45.10 (LOWBAND 1) DIVISION 2- RICHLAND, INGLESIDE, TARAVAL
45.14 (LOWBAND 2) DIVISION TWO- MISSION
45.58 (LOWBAND 3) DIVISION ONE- CENTRAL SOUTHERN TENDERLOIN
45.46 (LOWBAND 4) DIVISION ONE- NORTHERN PARK
They didn't spend any extra money equipping the patrol cars with lowband as backup. Prior to the late 90s, SFPD used these same lowband radios as their primary car radios (using those four non-repeated lowband channels), and 400 MHz portable radios called PICs. Essentially their cars were on one radio system while their portables were on a completely different radio system, so each division had a car channel and a portable PIC channel assigned to it.
When SFPD upgraded to their 800 MHz trunking system around 15 years ago, the vehicles and portables were upgraded with Motorola Spectra mobiles and XTS-series portables, both of which operate on the
same radio system. However SFPD was so set in their tradition and way of doing things that they refused to allow the cars and portables to be on the same dispatch channel and continued to keep them on separate talkgroups. Taking Central Division (3Adam units) for example, every mobile radio is on PD-A1, but every portable radio is on PD-A2, and they may talk to two different dispatchers depending on which radio they use. Furthermore, they still call the 800 MHz mobile Spectra Radios "Lowbands", and the 800 MHz XTS portables "PICS" (after the 400 MHz system)... same reason, out of tradition, and training has never really changed.
The actual lowband radios are just kind of "there." My friend at the department told me there's no formal training on their use as a backup system, and he was under the impression they were there for mutual aid use with outside agencies. I tried my best to explain that actually, "this was your original lowband, before it got replaced with your new lowband... which isn't actually a lowband."
Also I hear the Motorcycle traffic division (company K) may occasionally use the lowband system. Their IDs differ from patrol because they start with a 4 instead of a 3.
