Hey everyone, I live in South Charlotte, NC and usually listen to CMPD South and Providence channels, NCSHP Troop H/Meck County, and Charlotte Fire.
I currently have a Larsen Tri Band 150/450/800 hooked up by a Trunk Lip Mount(Antennex L Bracket) with a coax going to my Home Patrol which is mounted on the windshield.
I usually get good signal, but the radio will get very choppy when going through certain bumpy parts of the road. Would getting another antenna with spring on it be more helpful? Most of the time it is very clear when i'm stopped at a light or not moving. Also would it be better if i sanded all contact areas from the bracket to the car? I know a better ground is always what you strive for with L Brackets and Lid Mounts, but would it get the choppy-ness to go away?
My squelch is at 3 bars, I'm not sure how else to describe it, i just go by the home patrol(i'm a noob at scanning) and Signal Attenuation is off. I ran the cable in a way where the wire does not bend any more than 90 degrees. Heck it's fairly straight the whole way even at the mount location, i ran it in the groove of the trunk.
Also doesn't CMPD pretty much just run an 800 mhz channel now and NCSHP uses VIPER, so would there be a more suited antenna for my area?
Would pictures of my setup help?
Thanks for any help you can provide!
