Shuttle Launch
nosoup4u
High Bridge, NJ
I have patched the shuttle feed from IRLP reflector 9356 into the Penn-Jersey ARC UHF repeater located in Warren County. If you are within listening distance, tune your radio to 443.850, PL 110.9.
rcvmo
Romulus, Mi.
In the Detroit area, the launch will be broadcast over ATV 439.650 MHz w/ voice ( channel 60 on your tv, set it for cable tv, disconnect cable server and connect an external antenna and watch). Best bets to view are from the Downriver area.
RCVMO
rdale
Lansing, MI
I think Detroit may be hard to pick up in NJ...
fineshot1
NJ USA (Republic of NJ)
johnyvico
im here in camden coutny what do we turn to here for the shuttle launch
elk2370bruce
East Brunswick, NJ
John, Thanks for setting up the patch. Monitored today on the T7H with a extended Diamond duckie and DFQ. Well worth the listening.
73
nosoup4u
High Bridge, NJ
I'm glad you enjoyed it. The feed wasn't all that great, and 3 minutes before the launch a bunch of systems all connected and messed up the feed. Then to top it all off, our power went out 30 minutes later.
As the hurricane season picks up, I'll be connecting to the voip wx net (http://www.voipwx.net/) and patching it over to the same repeater. I'll let everyone know when we do that.
