Are there any signal boosters available that could be used on a Uniden 350a? Thank you
DMJR318 Member Joined Sep 1, 2024 Messages 17 Reaction score 0 Location Moultonborough NH Nov 29, 2024 #1 Are there any signal boosters available that could be used on a Uniden 350a? Thank you
R rf_patriot200 Active Member Joined Feb 9, 2024 Messages 1,291 Reaction score 1,102 Location Freeport, Illinois Nov 29, 2024 #2 DMJR318 said: Are there any signal boosters available that could be used on a Uniden 350a? Thank you Click to expand... There Are, but they might degrade the reception you already have. I would upgrade your antenna, before spending on a Preamp.
DMJR318 Member Joined Sep 1, 2024 Messages 17 Reaction score 0 Location Moultonborough NH Nov 29, 2024 #3 I currently have a Larsen Tri Band Antenna paired with Uniden 350a
R rf_patriot200 Active Member Joined Feb 9, 2024 Messages 1,291 Reaction score 1,102 Location Freeport, Illinois Nov 29, 2024 #4 DMJR318 said: I currently have a Larsen Tri Band Antenna paired with Uniden 350a Click to expand... Are you using it as a mobile in your vehicle or at home ? At home, I'd suggest mounting the antenna as High as you can get it. If you're using it in your vehicle, then you're probably good to go.
DMJR318 Member Joined Sep 1, 2024 Messages 17 Reaction score 0 Location Moultonborough NH Nov 29, 2024 #5 Mobile application
R rf_patriot200 Active Member Joined Feb 9, 2024 Messages 1,291 Reaction score 1,102 Location Freeport, Illinois Nov 29, 2024 #6 DMJR318 said: Mobile application Click to expand... I think a preamp in your vehicle is going to overload your scanner's front end, and hamper your ability to hear much.
DMJR318 Member Joined Sep 1, 2024 Messages 17 Reaction score 0 Location Moultonborough NH Nov 29, 2024 #7 Do you think I should upgrade my unit? Size is an issue. What would you suggest?
jtwalker Member Premium Subscriber Joined Dec 3, 2012 Messages 2,763 Reaction score 3,055 Location BEE00.1E8-1.22 (or) BEE00.689-1.13 Nov 29, 2024 #8 What problems are you having with current scanner? And what are you trying to monitor (not frequencies, but what systems/departments/agencies/etc)?
