signal generator
ryanpape
San Antonio, TX
I'm wanting to get a signal generator that can generate an 800mhz output to be attached to an antenna of a radio configured to decode digital audio on a conventional channel.
The source will be discriminator output of a scanner and ultimately a computer.
Has anyone done this? Any suggestions on what exactly is needed would be grealty appreciated.
I apologize if this is not the correct forum for this type of question.
Microwavemike
Dallas Tx
Sig gen
Ahhhh....WHAT? Ok It looks like you want to use the signal source as a Local ocsillator that then would feed a mixer that would then up-convert the Lo and the IF of your scanner to a 800 Mhz channel. Good idea. You will also need a way to filter the LO out of the product of the mixer.
Most scanners have a IF of 10.5 Mhz. You would then ...say use 800 Mhz from your signal generator to produce a product of 810.5 Mhz. That product then will have both the 810.5 signal and 800.0 and 10.5 in it. You will need to have a filter that wpould only pass the 810.5 signal. That you will then feed to your radio antenna port. It would be a good idea to also reduce that mixer product with a 20DB pad. Most radios will recieve signals well below -100 DB or about 2 microvolts of RF.
Nice project. Pick up the signal generator on E-bay. A HP 8656A would be a good one... should cost no more than $ 450.00. In fact the mixers are also found there as well as the pads. The filter you are going tohave to build.
Good luck
mm
Microwavemike
Dallas Tx
I have never heard of anyone attaching a sig gen to a antenna. However the HP 8656A does have a protection circuit to prevent Rf from going INTO the generator.
mm
N
N_Jay
Guest
mm
A little knowledge is a dangerous thing!
