Hey guys, I have an older Peterbilt daycab semi truck that actually came from the factory with a co-phase coax and after digging into the upper part of the cubby area a little bit further, I found out that the two coax cables that come from the antenna mounts on the top of the mirrors have those BNC type connectors, kind of like what you would find for the antenna connection on a scanner that plugs into a Y cable which is what plugs into the back of the CB. I found out that by unhooking the coax that goes to the passenger side antenna gives me a little bit better SWR but now I’m curious if my SWR could be even better if I was to remove that Y cable that doesn’t have anything connected to that one end and get me the same thing but just basically an adapter cable that goes from the BNC type connector to whatever the connector is called that goes to the back of the CB because wouldn’t I have significant signal loss coming out of that one end that doesn’t have anything connected to it?
