signal strength meter issue on a pro 651
ronw
dexter michigan
a freind of mine just bought a new pro 651 scanner. i programed it with arc 500 just like 20 other pro 106 and psr 500 scanners. the scanner performs flawlessly. however the signal meter only shows one bar. if you place the scanner next to another it performs the same only signal strengh meter only shows one bar. any one else ever ran into this issue with a pro 106 or pro 651. if so is there an easy fix. any info would be appreciated. thanks in advance.
If the software has a reset to defaults .. try that. I have seen that same issue on the PSR800, and that resolves it. You can then alter your scanner settings as needed after.
Nasby
Ohio
There is a thread about this somewhere concerning the PRO-652/PRO-651.
You need to go into the RSSI settings and change/lower them on the PRO-651.
