SDR# Simple DMR plugin and SDR# 1920
AkaStranger
thanks for getting back too me. Iv tried those things but to no avail unfortunatley,its still so quiet that its unreadable. Like i put in my previous post i could get the a previous plugin version to work well but only in AM,the audio was loud and clear,but iv now overwritten/lost that version whilst updating to the latest. Do you have a copy of the old versions?
edit: what SDRSharp AGC settings would you reccomend for this plugin?
Also, with all the maximum sound settings, the decoded signal is very quiet, I don’t understand how to make it louder. old versions are in the archive from post 4 if I'm not mistaken
morgy
Are you using the file that was made available for SDR# 1920 that was posted above?
Yes im using that now on 1920. Iv seen i little bit of improvement after putting on all available AGC's and adjusting the bandwidth to about 9000. It is still quieter than an older version i mentioned on v1919 that would only seem to decode when set to AM
thewraith2008
When I released that fix, I was told the level was fine.
On testing here, I found it to be OK as well.
Not sure why you can't hear it well.
AkaStranger
DMR and APCO 12500 bandwidth. I uploaded the SDRSharp.DMR.dll files again
and SDRSharp.APCO.dll from the archive and it worked for me. NFM 12500 bw -20dB, sound acceptable
morgy
i can confirm the same,just went over all the files and replaced them on v1919 and v1920,now there both working great and the audio is much louder now!
Maybe i wasnt overwriting the old files for whatever reason??
ormetkruper
Dals Langed, Sweden
Any chance you have the time and will to make it working with .1921/22 ?
With 1921 (and of course 1922) it throws a crash.txt and a plugin error. I am using the newest fix file. Or I am doing it wrong?
  • crash.txt
  • PluginError.txt
thewraith2008
Use the 32 bit (x86) version of SDR#. You can still use it in a 64 bit (x64) Windows.
All the plug-ins are 32 bit anyway.
Don't use beta versions of SDR# and expected plug-ins to work.
