SDS100/SDS200: Simple trunk display question
BlueMoon2
Midlothian, VA
In the bcd436hp that I had, it showed unit I’d just below the talkgroup number on the screen. In the sds100, it appears the only way to show unit id on that is to put scanner in trunk detail mode. Am I missing something? I’m still getting used to this scanner. It is quite nice though!
werinshades
Chicago , IL
Yes it can, under Edit Display. I have Unit ID Name on the line below the Department and above the Channel Name.
bkramm
Benton County, IA
I have mine on the simply trunked display on the line below the last avoid.
That way you can get up to 30 characters if you put the unit ID name 1-16 on the left then 17-30 on the right.
I have the unit ID for the number on the line above, same line as the bottom avoid on the right.simple trunk.jpg
