Simplex channels
Gilligan
Hagerstown, MD
Simplex channels are basically just radio-to-radio (not using a repeater to increase range). Talkaround simplex is direct communication on the output frequency of a repeater (thus talking "around" the repeater). Think of simplex as car-to-car or handheld-to-handheld. No repeater.
foggymoon
Cheyenne Wyoming
Thanks for the info. Is it a good idea to use these frequencys and if so how do you program them into the scanner with the software?
DickH
If you are referring to a trunking system, simplex freqs. are freqs. that are not part of the trunking system. They are conventional freqs. used when in buildings when the portables can not reach the repeaters. They can also be used for surveillance or just when you don't want a conversation going over the entire system.
n4yek
Cosby, Tennessee
It is always good to have freqs to listen to, even though you won't hear them too well unless you are close to them. Just enter the conventional freqs just like you would any other conventional freqs, no special need for them unless you see they are using different 'pl' tones and them you must make sure you enter those. (if your scanner has the capability)
Take care.
rvictor
Milwaukee, WI
Take care.
Actually there's no need to enter a PL tone unless you want to limit what you hear on a frequency to just those transmissions with the entered PL. If you leave the PL unentered you'll hear everything on a frequency and you may discover things that you hadn't expected to hear.
Dick
foggymoon
Cheyenne Wyoming
rvictor
So when I enter a simplex channel into the software manually do I choose a auto tone? What do I choose for tone?
Astrak
Mesa, AZ
rvictor
It depends on what radio you are using. If the radio has an option of just leaving the CT/DC/NAC to search or auto then leave it at that.
rvictor
Milwaukee, WI
With respect to a scanner, if you set the frequency with no PL tone associated with it, you will hear everything on that frequency within range. If you ONLY wish to hear Agency A, you can program in that agency's PL tone and the radio will only produce audio when it receives a signal on that frequency with that PL.
If you want to hear everything on the frequency EXCEPT Agency A, you can program that agency's PL tone as a tone lockout. The radio will produce audio when it receives a transmission on that channel that does NOT contain the PL. An example of this would be--There is an agency in my city on a particular frequency that does not use a PL on its signal. There is an agency in a city quite a ways away on the same frequency. Normally, that presents no problem. However, when the band is open, I will hear the distant agency which I have no interest in hearing. If I set the tone lockout to the distant agency's PL, I don't have to listen to their transmissions.
My personal preference is to not enter PLs unless there is a specific reason to do so. Others will have other preferences, I'm sure.
Dick
