Simulcast Problems
RandyVick
Local jurisdictions commonly using simulcast. Problem is I don't have schools, etc. in my programming, but those are still picked up on simulcast channel. I can lock out, but don't see them for download and including in my file so don't have to temporarily lock out each day. Any suggestions on how not to pick up those unwanted broadcasts?
fredva
Virginia/West Virginia
Can you give the jurisdiction you are listening to, so people can look at it in the database and perhaps get a better understanding of the situation?
ScannerSK
Weld County, Colorado
Where are you located and which system are you monitoring?
It sounds as if you are monitoring the voice channels manually rather than allowing the scanner to track the system automatically via the control channel(s).
Shawn
ofd8001
Louisville, KY
If you are using a Uniden scanner, I'd suspect you are in ID Search rather than ID Scan.
ID Search will monitor all the talkgroups in the given system except those you lock-out (as you described).
ID Scan will monitor only those talkgroups you have programmed, except those which you lock-out)
RandyVick
Any
Suffolk, VA, but same applies to any simulcast.
I'll check the ID search vs. scan.
ofd8001
Louisville, KY
Unless you deliberately or inadvertently programmed the schoolbus talkgroup, ID Search is more and more likely.
Also this issue would be true regardless of the trunked system being a simulcast or "regular cast".
