Hello. Can you run a single coax cable to your roof (of a home) and then have a splitter to have multiple antennas? I have a CB, Ham, and scanner radio and would like to put up an antenna for each. But does that mean I need three coax cables? I already have a coax going to the attic (connected to all tv connections in the house). Is there too much degradation to use those?
It can be done with a diplexer. The problem with that is that they take large chunks of the bands and split them off to specific ports.
So, you might have an HF port, which would be good for your CB radio.
You might have a VHF port, which would be good for your ham radio, but it might do something like 100MHz - 300MHz on that port.
And say you want a dual band ham radio, well, then you need a UHF port, or a port that does 144 all the way through 450MHz.
That's all great, not a problem. You can buy those.
But then, where do you connect your scanner? The VHF and UHF bands are going from your dual band antenna to your dual band ham radio, and all the signal will go between those ports, and none to the scanner.
For a CB radio, a 2 meter/70 centimeter radio, you can buy diplexers that will hand that over one coax.
But the scanner is the issue, if you want to use the full capabilities of it.
So, best you could do would be 2 coax runs. If you are going to do 2, why not do 3 and skip the diplexer. That'll save money, and all diplexers have a bit of loss to them.
