dellavalle
HELP,... I just purchased this expensive antenna and it either appears to be faulty or I do not understand this : from right out of the box, I tested the center pin (female) to the outer threads, ground, and it shows a fault. A dead short. After I rechecked many times, this antenna from the top of the mast, 17 up to the bottom tubing, all connected shows a continious flow to the center electrode, the female pin. I decided to run the cable to it, and installed it to my base, it works, but I am way high on my SWR range, why?
