SLATER locations
W0TLP
St. Louis
Looking for input from a St. Louis Area Trunked Emergency Radio (SLATER) expert:
Is it correct that the system frequencies at the tower at the St. Louis ****y Health Department, 4580 S Lindbergh Blvd. (I think it's listed as Site 102 St. Louis Area Trunked Emergency Radio (SLATER) Site: StL Co - Urban South) and the frequencies at Affton House 2, at 8124 Valcour, are the same?
If so, I'll point a Yagi antenna toward the tower at the St. Louis Police Department's South Patrol Division to resolve my reception challenge of that site.
scanman1958
St. Louis
Yes to your question. All of the towers located "south" on the SLATER share the same frequencies. That's what gives it a simulcast designation. The "north" towers share another group of frequencies. The system yransmits both sites (101 & 102) together simultaneously.
W0TLP
St. Louis
An older bearcat 996. It works fine. My location is n a shallow depression and distance + Line Of Sight make reception of STLFD inconsistent.
I'll run a Yagi antenna pointed to south patrol. The Affton SLATER tower lines up along the same path.
scanman1958
St. Louis
If you live in the south county area and will be using a yagi, you could point it toward the antenna next to the old state hospital complex. That is a tower for site 201 and is at the highest elevation in the city. That could help you receive city fire.
W0TLP
St. Louis
Yes. Thank you. That's the tower I'm referring to by the STLMPD South Patrol.
bdzig
Manchester, Missouri
This issue that you will have with trying to pick up both SLATER and the city site 201 is that both are setup as simulcast sites (LSM). The 996 scanners do a poor job of picking this sites up. Surprisingly, you may have better luck not placing an antenna outside. If its the 996T, don't count on receiving it, if at all. The 996XT are better, but still have the same issues.
The other thing to try is to adjusting P25 decode level. See the following discussion:
W0TLP
St. Louis
Interesting. Why difficulty picking up a simulcast site?
Mine is the 996T and it picks both SLATER and MOSWIN in the city but not great. I'm running a groundplane antenna in the attic and have too much coax. So I'll make a shorter run of better coax and swap the antenna to a yagi.
scanman1958
St. Louis
Your yagi can help with the simulcast distortion. Not sure what coax you have but a shorter length is good and a low loss coax even better.
