- Joined
- Oct 24, 2013
- Messages
- 776
- Reaction score
- 90
Does anybody know the tones for st louis county south fire dispatch for my unication G5 pager? TIA
Yeah. I know. Those im talking about. Do you have the code ranges for my G5? the pps asks for the ranges for p25 digital trunking tgids.There are no tones on SLATER for the north or south region based on department. If you listen carefully, the tones that go out indicate the level of the call (still alarms/medical, vehicle rescues, first alarms). The VHF dispatch frequencies are being maintained as a backup, but not regularly used.
So the g5 can alert to the tones with the ranges.There are no tones on SLATER for the north or south region based on department. If you listen carefully, the tones that go out indicate the level of the call (still alarms/medical, vehicle rescues, first alarms). The VHF dispatch frequencies are being maintained as a backup, but not regularly used.
Ok thanks. Which tones are these? Hi lo or the 5 beeps?Try 800 and 1500 Hz.
Should be hi-lo. The 800 hz should also be your still alarm tone.
What's a "still alarm" I hear it oftenThere are no tones on SLATER for the north or south region based on department. If you listen carefully, the tones that go out indicate the level of the call (still alarms/medical, vehicle rescues, first alarms). The VHF dispatch frequencies are being maintained as a backup, but not regularly used.
From a different thread...What's a "still alarm" I hear it often
If a call came in via telephone alarm or if a citizen reported directly to the firehouse an alarm of fire, then it was considered a "Still" or "Still Alarm" because no action took place over the Gamewell system. Meaning "the bells stayed still".
All the tones youve given me work. ThanksShould be hi-lo. The 800 hz should also be your still alarm tone.
The south main tg. 54756.There shouldn't be any police traffic on South Main. What are you hearing them say?
You may want to check what talkgroup numbers you are picking up.
All that the tones indicate is the type of call. In reality, Samantha (the computer voice over the dispatch talkgroups) is a backup to the 4-5 other ways that the depts get called out now so there is no need for depts to listen to it regularly.
