SLR 8000 Repeater Faulty part
Rahel
Hi,
I have SLR8000 VHF repeater and it has an issue with output power.... I checked the power with the power meter and there is 0 output power on the TX.
Moreover, I have requested a new part for each of the Modem Module and PA from Motorola, after receiving the parts I replaced both but still, the issue is there and after a while on switching the repeater ON the LED status goes RED...
Any technical help in this regard, thanks.
Rahel
Have you read the repeater with RDAC?
Yes, I've used RDAC to detect the issue but after a while of switching ON the repeater the Status LED goes red..... and after that the connection will be lost because the repeater goes non-operational mode.
Tech21
Hi,
Does it have an antenna relay? Do you have it connected to a duplexer? Are you sure you have the connections going to the proper place? Go into the codeplug and set all alarms to minor and write the codeplug. After that connect the repeater to a power sensor/watt meter and a dummy load. Connect a hand mic to the front panel and key up.
Rahel
Yes, I did what you said exactly... But the problem is not the connection the repeater is connected to Dummy load but after a while of switching ON the repeater status LED goes Red and CPS can't detect and read the codeplug...further what I read in the RDAC is there is an issue with PA voltage.
