SLR5700
KC1NHI
Is it possible to program an SLR 5700 with two digital talkpaths? One on slot one and one on slot 2. No matter what I try will only key up on one, and just get a denied tone on the other.
ramal121
Lots and lots of watts
Calif Whine Country
If you do a simple set up of the repeater (assign color code, then fill out needed info in the zone window) it should work on both slots no problem. I think your radio is the problem and not the repeater.
KC1NHI
Could be, it is a new r5. I have set that up with two different talk groups two different time slots both on different colors and still having issues.
spitzman
Washington, IL
I'm interested in buying a SLR5700 to do the same thing as OP. So with the same CC this would be possible to have two TGIDs simultaneous, one on each time slot?
K2NEC
5F6
Correct
