Voxcall API's
Muxlow
Super Secret
Middlesex County
Wondering if Voxcall and upload to 2 different API's and URL's in 1 instance of the program
DSD+FL is decoding the audio for DMR and also scanning an analog channel, Voxcall is monitoring that and sending to out to RDIO-Scanner. I want to use that same setup but send it to a different rdio-scanner url with a different api key. Is it possible to do this using a comma or something or it only supports 1 thing?
Iv got another voxcall running but with the other rdio scanner info in it and it works but seems to keep getting locked up saying its recording when its not no matter what audio squelch i adjust
grahampaull
I will modify voxcall to allow streaming to multiple Rdio-Scanner instances and attach it to this thread if that suits? Give me a few days and I will reply to this.
I currently have a very customised version of Voxcall that I use, this allows me to feed 8 audio lines into my rdio-scanner, this works pretty good.
Enjoi19
Ontario, Canada
Send it downstream via Rdio's admin panel to the other instance.
Muxlow
Super Secret
Middlesex County
Issue i have with that is im sending audio my my voxcall to another persons RDIO server so i have no control over any of the settings outside of voxcall on my computer here. Wanted to be able to send 1 audio feed to that RDIO still with the correct API key and, rdio url, tg and system id. Plus send that same info to my own RDIO i have on my pc
dispatchgeek
Control channel goes "brrrrr"
Between the cornfields and the pastures, Michigan.
I would find the ability to have 8 lines running into voxcall very useful!
grahampaull
Ok, so you want to send the exact same audio to 2 separate Rd
Muxlow
Super Secret
Middlesex County
Yeah want to take the same audio input and send it to 2 different RDIO setups. But only have to run 1 instance of voxcall. Seems when i run two voxcalls from different folders i cant select the same audio source. Its either 1 or the other.
Using DSD+ to get the audio and sending that over the virtual audio port. Its no biggies if its not possible.. setup iv got going works just wasting extra resources is all. Scanner and another laptop. But if it could be all done from a single voxcall then woo wee
grahampaull
Can you give this a whirl? I was able to package this up using PyInstaller so it should just run the same as before.
I have removed the OpenMHZ and Broadcastify sections.
I tried uploading to RadioReference but I hit a file size limit so I here is a link hosted from my Google Drive: VoxCall-DualRDIO.zip
I will publish this to Github also so you can inspect the source and make changes if you wish. I will post a link to this thread once I have this published.
Muxlow
Super Secret
Middlesex County
Seems it dont like windows 7 (my streaming pc)
Gives 2 errors
program cant start because api-ms-win-core-path-l1-1-0 dll missing
and
LoadLibrary module cant be found python311.dll
grahampaull
Ah, I hadn't tested on windows 7. I'll get that patched and reuploaded tomorrow.
blacks1
is it possible to provide this modified?
TNX
smackdaddy
Hi Graham,
I'm interested in getting a copy of the 8-input version of Voxcall if possible. That would be very useful!
Cheers
